Last update for 2022.
More bashing about on the King tender chassis, tipped off by Ozzy O the first task was to strip down the front end. The fold up etch that holds the weigh shaft trunnion bearings is too wide; out of the box it's 43.6 mm but needs to be 36.6 mm. The problem with the original width is that it will conflict with the front steps when you fold the turn in on the backing sheet.....that'll become more apparent later on.
Whilst doing that the last but one piece of white metal (vacuum brake lever) failed and fell off the shaft, in hindsight I should never have put it on in the first place.
Armed with works drawings graciously passed to me by a helpful modeler the rebuild could commence, the side sheets were moved in, weigh shaft shortened, a new centre bearing pedestal drawn up and fitted, new vacuum cylinder arm and new hand brake lever were also drawn up and fitted.
The final task was to draw up a new vacuum tank and fabricate some stretchers to hold it in place. I opted to make my compensation beam with double sets, this means that it passes over the top of the tank (just) and drops down to the axle. Some folks prefer a more swept arched beam like a long bow profile, in that case the beam will pass right through a lot of the tank. It's six of one and half a dozen of another, the long bow profile is easier to form and set up but a lot of work needed on the tank to clear it; the double set is harder to form but less work on the tank.
The floating axle top hat bearings bugged me, they just float in the slots with no means to stop them rotating, any grit or gummy oil later in life with seize them and the top hat will spin merrily in the inner chassis and wear the metal work.
I folded some 0.7 mm wire into a J shape and soldered it to the bearings, the long tail then passed through a 1 mm hole in the top of the stretchers. The bearings are free to rise and fall but will not rotate any more.
I still have the water scoop front end levers and cranks to sort.....but that'll be next year.
