Rob Pulham
Interestingly on some LNER coaches at least, it was the other way around - coach handle on left door locking handle on right. That doesn't help you with the mail coach however, sorry
Cheers Dave - thanks for that , certainly worth a try.Mike.
I thought Gibson use M1 crankpin screws and Ultrascale 14BA. These threads are quite similar, both being 1 mm O/D. The profile angle and TPI are slightly different, but I've found in practice that screws and nuts (perhaps including a shortened Ultrascale front nut) can be mixed and matched. It certainly might be worth a try at the risk of wrecking an Ultrascale front retainer.
Dave.
MikeDid I weight up the engine..no, I weighted up the tender instead. I also added the sprung buffers (Kean-Maygib). Transfers and a little bit of red paint for the buffer beam still to do.
But, the day was really made peachy by the chassis. I put the coupling rods on and it runs a treat - no sign of binding. The balance weights were added as well. I am really pleased. I also added the sprung buffers to the body, a REAL PIA (Alan Gibson).
The only blot on the landscape are the coupling rods. There is not a lot of room between the crossheads and the coupling rod. Whats even worse is that the coupling rod bosses are quiet thin. This makes my normal technique a bit redundant and as the wheels are Gibson I can't fit the Ultra scale parts on a coupling rod as the thread is larger than the Ultrascale one. So, if anyone's got an idea, I'm all ears!
But in better news I may have a solution to my shorting tender...and I have found the etch for a new chassis should it call for it.
A really good day!
Stay safe
Mike.
