@jonte
Hi jonte,
3D resin printing is not generally suitable for the timbering bases, except perhaps in 2mm/ft scale. The shrinkage is unpredictable, making it difficult to set an accurate track gauge. They also tend to curl rather than stay flat.
For the timbering bases the three available options are:
1. 3D FDM printing -- slow, but user friendly and low-cost. Can clip together in small sections.
FDM machines are slow but run unattended while you build the rest of the layout. This is EM gauge:
This is FDM printed base in 7mm scale:
2. Laser-cutting -- fast and can use natural wood, but more expensive and needs proper workshop facilities. This is P4 in plywood:
3. CNC-milled panels -- also needs a workshop. This is EM gauge milled in 3mm MDF:
cheers,
Martin.
