GWR 51xx
This post has been has been over due for at least 6/9 months!
As discussed in a previous post, the cylinders would not allow the crossheads to pass. Two solutions, open up the etch and re-solder or move the piston centres out. I went with option 2.
This is the etch as provided from Comet.
The parts circled (badly) are integral to opening out these centres. The centre of these holes are 4mm from the bottom of the etch. This is useful as when the smaller of the 2 is opened out to 1.5mm (same size of the tube used for the piston sleeves) we have a parallel line between the front and back of the cylinders. Next I scribed a line 1mm out. I should add that this 1mm measurement is purely guess work. A round file used to open out the holes to the corrected diameter. Then soldered in the brass tube.
I used the Brassmasters etch for the 43xx for the new slide bars and crossheads. What surprised me most was that these (slide bars) were the correct length and that the G hangers were in the correct place as well. He shoots and he scores...less work! The rest is just adding the detail.
I reused the drain cocks from the Finney kit. This time there was no messing about with the slide bars, the crossheads ran perfectly first time. Unlike the ones I built for the County which took a lot of fettling to get to run smoothly. Blame the builder not the kit...
Once this had been completed out with the air brush to push some matt black over them. Added the coal to the bunker and used micro sol for glazing the cab windows - which turned out really well...another surprise. This kit had one more surprise left, the fixing holes in the chassis actually married up with the holes in the body!
After 18 months of trials and tribulations this is done - a bit of weathering to do but that'll wait till next year when SWMBO goes on her hols again. More running in at Barrow Road in the near future.
Would I build another...umm, no. And fortunately I don't need to either.
So whats next...I fancy building some more coaches, namely my M set (the last coach set that I will need for Hengoed). So, there are 4 sets of 9 foot bogies to build first.
Thanks to everyone that helped with ideas that have got me through this build. And special thanks to my pal Morgan Gilbert for sorting out the third set of wheels
Stay safe
Mike.
