Mike Garwood
So a quick date on the coach, bogies built and the coach is running away in a small breeze, Mr Bedfords best. It's in it's box awaiting some nice weather to paint and line out.
In the meantime I've opened the etches to the 3P. Love the look of new etches, there are many pieces that require rivets being pressed out. I have the correct tool for this, so this isn't a problem. But having never done so many in one piece of work, is it better to do this while the etches are in their border (if you know what I mean) or is it better to take them out of the borders?
First thing will be the chassis and associated valve gear, if I can't get that to run smoothly, then it'll be pointless in finishing it. Gearbox will be High level, wheels are Ultrascale but I can't decide on a motor. I have a left over Mashima 1624 - which was destined for a Black 5 - and I have some motors I purchased from Cambridge Custom Transfers. Or I could just buy one of the new motors from High level.
The other slight problem is the spacers that go between the chassis are only 14.2 mm wide, I think this is a bit narrow for a P4 engine, as it'll mean quite a few washers to take up the slack on the wheels. The NS etches are made from 0.4 mm so that gives 15 mm over the complete width of the chassis. Something to ponder.
Any advice appreciated on these choices.
Stay safe
Stay safe
