Thank you Graham, David and Ozzy. In the end I decided to laminate the said pieces and then cut through them with a saw and tidy up with a file, seemed like the easiest option and worked fine.
After that I laminated the central and intermediate cross pieces.
Then folded up the long centre sections, parts 8 and 9.
I wanted to use these to locate all of the cross sections correctly and that they would all sit down correctly on the main fret later.
Two things here, soldering not as always neat as I would like but I have never built anything this long and feel strength is important. Secondly, although I have a 6mm sheet of glass, it isn't completely flat when I look along the length of it. But it will do, have you seen the price of surface plates?
Centre parts 8 and 9 here again, just checking all the slots and tabs fit (I know, David, they always do).
So all of the cross members soldered in place ready to be cleaned up. The main thing for me here was to make sure all the slot and tabe would fit perfectly when I came to the final soldering up.
And sat on the nearly completed bogies.
Ken
