SteveB
Hi Dave
It's a 1ltr bottle and if I had drunk all of it in one go then I probably wouldn't be writing this post.
I have thought about putting decoders into the tender but there's an awful lot of wires. Each smoke unit has four wires, two to the motor and two for the heater. I know I could use common return (which I do already) when there are multiple units but nevertheless its still a lot of wires. Wouldn't it make the flex between the loco and tender too rigid?
I know what you mean about trapping wires, its happened to me more than once. Its easy (for me at least) to do. I'm just playing around and experimenting, so nothing is too permanent yet. There is actually a small piece of vero board under the decoders where multiple feeds have been taken. I've put a small plug and socket on that so I could easily isolate the decoders from each other.
Any chance you could put some photos up of what you've done, so I could get some inspiration?
Steve
Just looking at your photographs of the 8F installation could the decoder(s) be mounted in the tender and carry two or three wiring looms to them?
Or mount all the sockets on a piece of PCB to reduce the wiring. This is something I now do to reduce the chances of any wires becoming accidentally trapped/caught or broken.
Steve
