SoundsLoco
Member
Hi Paul
I’ve played around a bit with varying the heater temperatures using CV137, 138 and 139 but I must admit, not much. I’ve got to be careful here because I don’t really understand what I’m doing but despite the heaters going through a relay they do seem to respond to changes to these CV’s. The relays are solid state and I guess CV’s 137 to 139 change the voltage by PWM. My very basic and crude understanding of this is that it turns the relay on and off (at high frequency). Regardless of whether my understanding is accurate, they do change things. I also monitor the power consumption, just to make sure I’m not cooking anything, and I can see and power reduction when I reduce the value in the appropriate CV.
Do you think I would be better off using sync discs? I’ve just ordered some from NG Trains so I can have a play with them.
Do you happen to know if CV60 would affect the voltage on F04 when this is being used fan sync?
Steve
OK, I hadn't considered the type of relay you are using and you have the advantage of practical experience, so if the PWM duty cyles are being passed on by relay to the heater that's a problem solved.
The values given in the decoder manual for CVs 137 (Standing) 138 (Cruising ) and 139 (Acceleration) are a bit on the low side. There's no need to be concerned about experimenting with these values. The maximum is 255 and this is equivalent to 'always on' (at track voltage, current depending upon the heater elements), and figure lower than this in any CV willproduce an 'attenuation' of the effect. try it ot, you can easily put the values back again if you do not like the results.
The Seuthe type smoke units are little more than boiling tubes, but its possible to automatically (by the sound project) vary their output depending upon status using these CVs.
Also, have a look at Cv355. This controls the fan speed at standstill. A combination of Cv365 and Cv137 should allow a constant but slow, less dense vapour when standing.
The value in CV60 is used to dim all function outputs which are not specifically 'masked' from the effect. I don't know if use as fan sync, which is a special case, masks the fan fom any voltage dimming. I suppose the way to test would be to get this running then change Cv60 to a dramatically low figure, say 50.
Good luck, I'm off for some food,
Paul
