Good evening, fellow Westerners.
Having cleared away most of my modelling materials and tools prior to the weekend, it took a lot of gumption to make several dashes to my den down the garden to retrieve them, due tothe torrential rain and high winds that have blighted the northwest over the last day or so. So, looking like I’d been dragged through a hedge backwards, I reluctantly - why is it so easy to get out of the swing of things, even after the briefest of lay-offs? - picked up the tools and had a good ‘thunk’ about where to start.
It seemed logical to cut and glue the parapet above the mouldings, as I think that was where I’d left proceedings. I learned that this was best done in stages as with these long lengths - especially where it involves applying glue to both surfaces to be joined - the glue has gone off before you can offer them up
That done, I moved on to fitting the moulding above the new doorway, which had to be narrowed in width and then sanded/filed thinner as I had no suitable styrene section in stock. This and other areas will need filling before priming, but this could wait as there were other matters to address first: one being another legend I wanted to hang above the new doorway, in the form of the abbreviations of the founding railway company (Chester and Birkenhead Railway) to enhance (?) the air of vintage-ness I’m so, desperately seeking for the place, in order to try and give it an ounce of credibility
Why the C.&B.R.? Well it was the builder and owner of the original Monks Ferry station on which it’s remotely based, so there was some other rather far fetched parallel with my own humble offering.
Here’s where I’m up to:
It took a whole afternoon ‘crafting’ that Ampersand-ey looking ‘and’, using sections of cut up letters from the Coopercraft sprues I’ve been using. I suppose somebody somewhere manufactures them, but hey, I’m not being that precise to warrant halting the build. Like everything else here, near enough will have to do, if you can call it ‘near enough’
It was supposed to have had the framing fitted this evening to match the previous incarnations of ‘Goods’ and ‘Patrons’, but I took time out to watch my boyhood club instead, and once again wished I’d just got on with this instead
With work (slowly) progressing on the station building fascia, thoughts have once again turned to how the overall train shed roof will be mounted, especially at this end, so I’ve decided to run with my initial idea of just continuing the steel beam across the parapet (to give you an idea):
Now I look at it, it’s less than ideal - I think the builders probably would have had the beam arranged to sit behind the ‘dressed’ parapet, but if I was going to do this, I should have cut off the top underneath the uppermost moulding as asserted a few posts back, in order to accommodate it. Never mind; too late now. I think it should be alright when painted and it will make the siting and un-siting of the roof for cleaning purposes a whole lot simpler - and after all, ease of use is my priority
So there we go; not a lot of progress,,but at least I’m back in the swing. The next task will be to build some door frames for the new doors and replacement door, then I’m thinking of adding some simple relief to the window frames to make them look a little more realistic. Once done,I can prime and then return to the pressing matter of joining up the roof beams
Cheers for now.
