SimonT
Jon,
this is very interesting. I have concluded that SG90s are the way to go and again, I am moving towards the MERG solution. A couple of questions:
1. What form of control are you using? I use DCC (Lenz and SWD/ESU chips) and as yet I haven't seen anything to indicate any from of interference between the systems.
2. Do the MERG boys know about the problem?
Can we mitigate the interference?
3. How close are the power supply buses, including rails, to the servo control wiring?
4. Have you tried placing a capacitor across the pick up wiring to suppress the effects of the arcing/interference?
As a large number of the signals are now permanently mounted to the baseboard, I am going to have to come up with a method mounting the servos on the baseboard. This will be complicated on the triple doll. All the signals are operated by .7mm wire droppers that push the signal off. The yard starter and the gantrys will need to be removable from the layout to protect them in transit; this will need some very careful mechanical design, not to say building.
