Ressaldar
Working wipers?
nah
Working wipers?
Colin,
Presumably we're talking about detail 46 on Gardner drawing L32 for the GER Water Gauge Columns?
How full do you want the boiler to be? I think I may be able to get a water level showing in the gauge glass... It won't go down as you drive tho loco around, of course, but if you fitted some micro-bore tube top and bottom then I'm sure it could be done.
"brilliant but barking!" gets a like from SWMBO! Well, the barking bit doesDave,
brilliant but barking! Do you think that the bolt will be strong enough to stop the stcok rail going walk about, a problem that cyano only partly cures with the C 7L/Exactoscale?
As you say your P chair drawings are of LNER design are they based on the 1926 95R BS Switch and Crossing drawings? If so they are likely to be of use to all non-GWR groups who, I believe, all adopted the same standards for new S&C work.
I have just had a look at the actual drawings for the Southern Railway P chairs and they look to be exactly the same as the drawings for your chairs.
I could be in for some very soon if you give the right answer.![]()
An over view of your products for the S7 newsletter wouldn't go a miss Dave.........if we shout lowd enough Richard might hear up in "Narfork"....."allo boy"
Col.
The book? LNER NE Area Permanent Way Standards 1926, isbn 1 873513 42 9, published 2002 by the North Eastern Railway Association. There's also a 1912 version for the NE Railway but neither seem to be currently available; at least I couldn't find them on the NERA website just now.
But isn't everybody in the S7 Group a member of WT as well?
I think I've got these Daveif you need any info.
Col.
............... then we can start the loco shed for West Mersea![]()
What thickness metal does the slotted guide allow ?
