I finally got the NB version of the birdcage built this evening. I've had an eventful time producing the parts and have had to have several goes to get all the necessary bits - mostly down to my finger trouble.
The Drummond NB version of the brake end was somewhat more complex than his later Caledonian version due, probably, to his use of an elliptical roof. Here are all the bits in the foreground with a pile of some of the rejects in the background.
I've now thought out a better way of putting the parts together and this was the guinea pig run to see if it was indeed better. My previous battle with the Caledonian end was getting the fit of the ducket sides correct between the ends - this was after having built up the inner frame, then sticking the outer parts to it. The problem of the fit depended on the thickness 0f the inner material being exactly correct and that is a bit difficult to achieve with my machining methods at the moment. I then thought about fitting the inner side and the two ducket sides together, then fitting the outer assembly - inner and outer parts - to the ducket sides, then once they have set, glue up the joints on the inner frame. All I would have to ensure was that the inner frame depth dimension was slightly undersize - by a thou or two - so that all would fit well.
So the ducket sides were glued to the inner face also ensuring that the inner side became the panelling on the ducket side.
Then with the two ducket sides fitted, the outer end parts were joined together and prepared for the joining.
With the top parts of the duckets joined
And then with the lower parts glued. This was quite fiddly to do with a lot of clamping by digits and fingernails.
. I think I will try and pre-shape the ducket sides to make fitting to the "S" shape a bit easier and less of a trauma. It has turned out quite well but I think I can make the method a bit easier and less stressful.
Fitting temporary window glazing - possible bits of metal strip - will help in stopping the glazing slots closing up.
Beside the NB end is the end of the Caledonian coach with its untrimmed roof in place. Old Dugald certainly made quite a few design changes when he moved to St. Rollox from Cowlairs.
And I am now using my new camera to take these shots and it is a much more pleasant experience than that with its predecessor. It also has a 24X optical zoom with digital zoom extensions and with image stabilisation so this next shot was taken seven feet away, handheld, at 28X zoom.
With all the recent discussions about cameras, this one is a Panasonic FZ150 - a bridge camera rather than a DSLR - with a 24X optical zoom and the ability to take HD movies. It has a 200+ page manual so I haven't waded through all the facilities yet. I only got it today and I'm just using the idiot's automatic settings at the moment.
Jim.
