lancer1027
Ok, the purpose of this thread is just to show you another of my little projects
As some of you are aware Ross has an Allegro, so i thought it would be nice to copy the colour and registration/number plates as the same as his and put it onto one of my motorail flats
The first stage is to take the model to bits :vista: :vista: . This was harder than i thought it was going to be . The reason was that the chassis is fastened to the body with rivets (not screws as i had thought ) so after about an hour carefully drilling (by hand) and getting a couple of blisters i moved onto the Dremel Wish i had started with this :x This only took a few minutes.
We now have a model of a Allegro IN BITS :vista: . The only damage thus far is the windscreen wipers are slightly bent as they are very fine. These should straighten out
[attachment=3:17a72wun]PICT1064.JPG[/attachment:17a72wun]
[attachment=2:17a72wun]PICT1065.JPG[/attachment:17a72wun]
[attachment=1:17a72wun]PICT1066.JPG[/attachment:17a72wun]
[attachment=0:17a72wun]PICT1067.JPG[/attachment:17a72wun]
The next stage will be to slightly rub the body to give the primer somthing to key to. Then i need to source some bronze spray paint .
More up-dates when i have some more done.
