OK then. The main problem with the loco was that it was powered using the American system - engine live one side, tender live the other. The problem being that when it was DCC chipped it shorted at every opportunity, even on straight track - think St Elmo's fire. The Heyside brains trust had all made suggestions, dutifully carried out by Roger, but all to no avail. I gave up when I tried it as an 0-6-0 and saw sparks where nothing was touching. Since we'd gone as far as possible without building a new chassis from scratch, which would rather defeat the object, the last resort was to strip out the shorting wires on the Slater's wheels and use conventional pick up. As I had just done tender pick up on mine, I decided to make Roger's tender pick up only. Simple eh? Er, no.
First of all, the tender derailed on points at every opportunity running backwards. I thought to measure the back-to-backs. Way out, like not even close. I took one pair off, and the reason was immediately obvious.
The builder had used the correct, but older style, Slater's wheels which had no brass boss in the centre. He had shorted them out by digging a trench right across and soldering a wire to the tyre and to a bearing. The current was transmitted by trapping the bearing between the wheel and the shoulder on the axle, thereby automatically making each wheelset out of gauge by the thickness of the washer. The mess left behind when I removed the shorting wire and washer left the wheels unusable. OK, 2 new wheelsets from Slater's for the outer wheelsets, and I could make up the centre wheelset from 2 of the original wheels that hadn't been
butchered shorted out.
I still had the problem of getting the centre wheels out, the only solution was to break one side of the stretcher support plates to allow me to remove both wheels by withdrawing the axle from one side.
I also removed the ends of the support plate, which have no real function, to make changing the end wheelsets easier.
There is little chance of fitting pick-ups to the bottom of the chassis, but it is possible to do so from the top, with an alteration to the tank body. Namely the removal of the two large pieces of brass on the footplate that run internally from one side to the other. I would only do this after the body has been built as the footplate will otherwise become less stable.
From here on in it is simple. Copperclad is glued to the top of the stretcher supports and insulated into 2 sides, 0.7mm phosphor-bronze wire is added as pick-ups, and the copperclad wired to a engine/tender plug as shown in the pictures.
I also cut a 'U' shapped section into the top of the frames to eliminate any possibility of a short with the pick-ups.
It's up to Roger as to how far he wants to go with cleaning up/repainting etc, I'm just making it work. You would have a picture of the finished tender, but the camera batteries need a recharge, so that will have to follow, as will details on the engine rework.
