Nick Dunhill
So I have been sent quite a few pictures of AR class locos (Thank you Thank you) and yesterday I added a few bits and bobs which I hadn't noticed. The bottom of the firebox has some wash-out drain taps, there's some pipes sticking out of the sides of the tanks below the footplate (injector overflow?) and the air brake hoses. The latter are detachable to allow the painter to line out the buffer beam easier (and save him from breaking them off!)
I made a cab roof, and thanks to all those who were in touch about the long ventilator. It can be lifted off to gawp at the cab interior, and help the painter.
I also did my usual modification to the water gauges and cut away the cast square cover and replaced it with a length of square perspex rod. The rod has been drilled down the middle to represent the tube and a piece of paper with chevrons printed on it attached to the rear.
I had to make a regulator handle too.
So on monday I'll finish the backhead and start on the boiler. If anyone knows what the steam brake control on the backhead looks like please get in touch. Thanks.
