john lewsey
Very nice Rob I like it something quite different
Very nice. What is called, I think, a characteristic prototype. I wish more kit manufacturers would provide etched corner plates, as it much easier to get them to look like what they are supposed to be, a single folded piece of metal. Usually, with the plate in two halves, much filling, filing and rubbing down is necessary to get it right.
I have to admit like you I would have preferred one piece and folded, but they did go on quite well.Very nice Rob I like it something quite different
Peter made some by rolling lead foil around the pointed end of a pencil (with the point flattened to the width of the bottom of the bucket)... and then cut the top / bottom of the foil cone (whilst on the pencil end) to the required height of the bucket. As the bucket was lead he was able to solder a "bottom" and a "handle" to the cone. At least one of those buckets lives in a hole in the floorboards of a LNER 8-wheel tender.If not I will look for some that are a bit more bucket like....
Nice to see that this shunters truck is going to be AWS fitted(!)
I need a sticky out tongue cheeky emoticon here but I'm on an IPad so you'll have to imagine it.
