S-Club-7
The "automatic" gauge widening comes from the inclined rail which becomes more vertical as it is curved i.e. the foot of the rail stays where it is but the heads get further apart. At least that's how bullhead works, not sure if flatbottom does the same thing. A bit of schoolboy trig indicates approximately 0.32mm (about ½" full size) of gauge widening if the 7mm scale rail becomes fully vertical; probably depends on how distorted the chairs can get.I can't see how you can have automatic gauge widening on flexi-track as what ever radius it's curved to the dimension between the chairs will all ways be the same as when its straight, the chairs wont spread apart![]()
If you get a different answer then you obviously asked a different schoolboy...
Check rail required under 10 chains only if carrying passengers or vehicles "climb" over the outer rail.Gauge widening on the prototype was used on curves of radius
between 10 and 7 chains ...+1/4"
7 " 5.5 chains..+1/2"
under 5.5 chains.........+3/4"
All these must be fitted with a check rail.
