Nice!
Do you have any way of allowing the axle to rock sideways (roll, but that’s confusing), as whilst it can rise & fall, it seems to be fixed on a horizontal plane?
There is sufficient! It's part of the design I'll probably refine in the next iteration. There is a small top hat bush in the steel links attachment to the truck. Originally I had put a slight radius on the bush to allow a little roll. When the attachment point was at the rear of the truck it worked quite well as a "spherical bearing". Unfortunately moving the attachment point to the centre of the truck has restricted the roll a little. I think there is enough slack in all the joints for a little roll in the truck, but as I say it's one area I'll probably tweak on the next iteration. Every day is a learning day.
Now that was sorted I turned back to the main frames and horn guides. The intention is to fit miniature ball races and rather than castings or etchings I make the horn guides from a bit of brass channel. In this case I've use some U channel out of my raw metal draw and cut one side off to form the L shape.
For those of you with OCD may notice that the rear driver horn guides (on the left) appear to be slighty wider than the leading driver horn guides (on the right). That's because they are!
One thing I love about scratch building is looking at the drawings and trying to understand what the engineers of old designed. From looking at the GA drawings it seems on the Precursor Tank the rear driving axle actually had a 4-coil spring suspension arranged in a square format - the 4 leaf clover in the drawing below. Hence the horn guides were quite deep. My thoughts are to solder on a square plate on at the bottom of the horn guides and then 3D print a 4 coil spring representation to stick on later. There is an additional bracing plate across the frames between the left and right horn guides, that will be covered later on.
Then the leading main axle only has a twin coil spring arrangement. Hence the narrower horn guides.
Against one of the main frames I then clamped a straight edge across the top of the frames parallel to the horizontal datum.
The reason for this is that when I start soldering the brass angle to the frame I can use this with an engineers square to ensure that the angle is truly vertical in the frame.
Once the first horn guide is soldered in then I have a short length of 3/16 brass hex with a small flat filed on one side - it looks not too disimilar to a Monopoly hotel. This allows me to solder the other side of the horn guide in parallel to the first. Hopefully this means everything is straight, square and parallel. However this first one is critical, I soldered this one in and then walked away. I came back later and ran through my checks and it didn't feel right. Something wasn't quite lining up so I dismantled it and started again, this is actually the 3rd attempt with which I was happy.
Once I had the first one done to my satisfaction now is the time where a short stub axle in a horn block is used. With the steel coupling rods it now gives me the spacing to the 2nd axle on the main frames.
Now I had one side completed I can clamp the second side to the first. Using my "Monopoly hotel" stood upright through the two frames meant that I had a reference point to solder the horn guides on. [ note the small step between the horn guides and the main frames is to accomodate the top hat ball race. Hopefully more apparent later on.].
Now I have mainframes with horn guides fitted. Note only the first one was fitted "by eye" the remaining 3 have all been fitted by reference from the first. Hopefully this makes it all square when assembling.
Attention then turned to working out where to put all the frame spacers. Again reference to the GA drawing was useful and within the restrictions of the model I have tried to copy the full size where appropriate. For this build I have decided to try fitting the font and rear buffer beams to the chassis rather than the body, mainly for detailing and painting issues. It'll be interesting to see how it works out. As mentioned they did apply a bracing frame between the horn guides which will be cosmetic additions later on. The rear trailing radius truck is mounted on a frame spacer for fitting just behind the cab. The rest of the bits I've cut out by happy co-incidence seems to match pretty reasonably the etches
@mickoo posted a couple of days ago so I must be doing something right.
One thing I did note from the GA is that the rear frames actually have an additional spacer plate behind the rear drivers, so it is 3 plate width.
In Scale7 I'll take anything going so I have an additional spacer so that the rear frames are even narrower and give a bit more swing for the rear radius truck.
Rivet location and frames are marked out for the front of the main frames.
The one remaining spacer now to sort out is the bolster for the front bogie. It's going to need a 3D design to fit in properly. I have a couple of ideas in development but will need to leave that to the next post as I'm still thinking through the details.
