I don't wish to bore you all to death, especially when even a glacial pace would be preferential, but making windows this way really is one step forwards, two back.
But something, call it an effect, has come to light as a consequence of the method I've sought which might be of interest to others.
To recap, I'd left my window frames in soak in hot water and detergent at the end of the last post, in order to aid the process of parting frame from paper backing which had become adhered via a candle wax, primer and paint (several coats) bond. Although the back layer of paper came away easily, the thin front bit stuck like the proverbial you-know-wot to a blanket. Scrubbing with my wife's toothbrush (well you wouldn't expect me to use my own) resulted in this mess:
Concerned, I began cleaning it up with a scalpel, and to my surprise, it all came away quite easily. However, peering through my monocle (purchased solely for the purpose of adopting a true railway modeller like pretence of course, along with waistcoat, pocket watch and that rather quaint idiosyncrasy of using the abbreviated form of middle name twixt Christian and surnames, in the unlikely event that I actually enter and win the Cameo competition) I noticed that it feigned the crackled appearance of paint that overlaps onto the window pane. Well, to me anyway. So, rather than clean it all away I decided to leave it showing in places, although some may feel I've overdone it; and perhaps I have. Others might think it's bl**dy awful, and again, perhaps they're right.
Perhaps it's a case of classic versus modern in as much as the abstract conveys a mood: classic, in this case, being window frames that are white, square cornered and neat, whereas mine convey atmosphe....... . Sound like a lame excuse?
Actually, I do like the effect, and I suppose the correct term is that it provides a little relief to the frames.
Still, I think it's a classic Marmite affair: you either love it or hate it. I hope one or two of you might like it and even wish to use it on a future build, and so I just thought I'd share my happy accident with you.
On the bright side, I'm pleased to report that there were none of the anticipated casualties sustained during the paper removal and cleaning up process; these came later, however, when removing the edges of the plastiglaze with scalpel and emery board, so I shall have to make some more..... This is definitely not for the impatient among us!
Incidentally, once the frames were soaked, cleaned and left to dry, they seemed to lose their rigidity and became flexible like the plastic parts of those Dapol kits that you get in plastic bags. They're pliability resulted in them losing their squareness which didn't ease the process of sticking them onto the plastiglaze
whilst trying in earnest not to leave glue residue on the glazing.
Whilst I might like the effect as described, it would be a darned sight easier just to build the frames directly onto the glazing with MEK....I'd probably have finished by now.
In the following, the frames have been glued onto the glazing with Humbrol Clear, the excess being easy to remove with a cocktail stick before it drys. A casualty can be seen second from left in top row (frame split from bottom) and will need replacing. Btw, the thin white top coat came off during the scrubbing process, so a further thin coat will have to gingerly applied afterwards......without getting any on the glazing!
A couple that have been cleaned up.
And that's it.
Till next time, thanks for reading,
Edit: in that last photo, the frame has split at the bottom although this can be resolved when final fixing into frame.
