Well not quite, but almost.
Having fabricated some replacement windows for those that had become casualties of the final sanding process (split frames etc.), I discovered that several of those that had, were slightly taller in height...... A solution, or so I thought, was to slice the bottoms of the lower frame which perhaps could be hidden behind a batten, those at the top being too noticeable to mess with. In the event, they looked terrible, so there was no other option than to fabricate replacements of the correct dimensions.
Frankly, WTers, I was surprised at my philosophical attitude to the slight cock-up: my usual response would be either to chuck the darned thing out of the window in a fit of temper or travel hastily down to 'da Smoke' and drag a moped miscreant from his stolen steed and mete out some summary justice.
But no, on this occasion I calmly and collectively put it down to experience, and within the hour, new frames had been drawn up, makeshift jigs blu-tacked on, and the first cross members were dexterously being adhered together. I was rather proud of my new found robust approach; at last, I'd grown up. Then I knocked over a new bottle of solvent
that drenched the drawings, the jigs, the styrene sections, the modelling mat......and the table (guess who couldn't be bothered covering it in newspaper before he started? Well, the wife was at work).
On my return from North east London, I successfully managed to fabricate those replacements without further ado, and buoyed in the knowledge that the patience testing task of signal box window making was safely behind me, I was eager to press on with other parts of the build. So, I turned my attention to building the frames for those dratted windows.
Generally satisfied with their outcome, and relived that I'd cut the sides to allow just enough room for manoeuvre without hacking out too much, I at last felt as though I was getting somewhere. Now, the frames - as far as I can tell - are true to the original. I say this, as the photograph in my possession shows only two sides. The rear I'm not worried about as it sits tight against a supporting wall, however, the side on which the signalman' s door and presumably locking room door are located are not shown in the photo, therefore, it's a work of pure fiction based on the design of similar boxes. However, even though I doubt this side will be seen, I decided to build the frame on the scenic side to match, which seemed the reasonable thing to do. Until, after it was built and the relevant side cut to fit, I realised the windows I'd made for that side were too big........
So, there was nothing for it, but to make some of a suitable size to fit. Back to the marking out, jig making, blurred vision and backache.
All of this preamble is just my long winded way of justifying my glacial progress, but now I know for certain that there will be no more need for window making thank.......!
All they need now is priming, painting, cleaning up and glazing, then they can be glued in the correct format before being fitted to the frames which themselves will require tidying up, priming painting and weathering before final fit.
Anyway, I'll shut up now and leave you with a photo of the frames slotted into the sides just to give you an idea of how they will look (and it's the right way up for once!).
Best wishes,
