topshed34a
Your correct and since I took this photo I have moved the front plate flush with the front. Now the problem is that I have to solder the front to the lower parts of the boiler but the edges of the front need to be curved as does the wrapper, not only that but it also kick back slightly in sympathy with the firebox.Sorry for not responding sooner and I hope you haven't soldered too much together. Looking at several photos online I think the top of the firebox should be aligned with the top of the boiler rather than having a noticeable step at the joint. The prototype cladding would have only been about 1/8" thick so even if one sheet lapped over the other it would barely be visible. I think the step appearance is visible on some of the C1 models, presumably the same kit?
This looks better but now I have the tricky work of making the firebox front and the front of the wrapper into a nice gentle 90 degree curve.
