I'll just carry on without it unless anyone has any suggestions as to where it might go (in the bin?).
I'll dig my model out and have a look see..... and take some photos which may assist.
Cheers Dave.I'll dig my model out and have a look see..... and take some photos which may assist.
I spent a few hours this afternoon trying to get the cab soldered together. @Yorkshire Dave provided me with the impetus to get this done and I don't think I could have done it without his pictures!
Half the time was spent unsoldering and then resoldering parts in an effort to try and line everything up. Currently it looks like it's being cut up in a breakers yard, but I'm confident that I can make more progress.
To avoid confusion amongst readers it helps to use the correct names for the rods - connecting rods connect the pistons to the wheels, coupling rods couple the wheels together.countersunk screw for the connecting rod screw on the leading driver
Cheers Rob!Looks better already.
It's another voyage of discovery!When you move the cylinders back make sure the connecting rod isn't too long.
Unless I've misread the instructions it appears I need to cut a few mil out of the mainframes to allow the cylinder block to move back its correct place.
The picture below should indicate how far out it is at the mo!
