Once again Dave you have come to my rescue!This is what should have been in the kit...
And I don't know if these will be of any use. I took them by poking the camera into the cab of the one on the Worth Valley when it was at Oxenhope years ago.
View attachment 211318View attachment 211319View attachment 211320View attachment 211321View attachment 211322View attachment 211323View attachment 211324View attachment 211325View attachment 211326
I see from Yorkshire Dave's photo that there is a hinged cover plate on top of the front buffer beam, which rests on top of the buffers. There is also an associated pair of lugs and chain attached locking pin on the smokebox front, which I assume could be used to hold the plate in a vertical position to access below it?
Cheers Dave.I must say, the cylinder/smokebox saddle area looks far neater now than it did in earlier shots. Your work in that area has certainly made a big difference.
Dave.
Decisions, decisions!All depends how far you want to backdate it.
As built......
.....or after the first set of SR modifications (cab side windows, backed/plated coal rails, and revised steps)....
.....or the second set of SR modifications (revised cab windows, enlarged bunker, additional lower gutter and roof vent) but retaining US injector fittings (as mine)....
Or leave it as the kit after the third set of modifications 1949-1951 (Ashford injectors, front buffer beam drop plate).
I doubt my effort qualifies for 'work of art' status, but I do have an image of how I want this locomotive to look. Unfortunately to achieve that image does seem to require a lot of upgrading/additional parts!This selection of mediocre parts is rapidly turning into a work of art. I’ve been following this build with great interest and you are to be congratulated on your endeavours.
A dirty black USA tank adorned with Sunshine lettering will look grand.
By way of encouragement, here’s my attempt. Pictured at early days at Stroudley Park. Keep up the good work Mr Spikey.
Regards,
Ian
