Ummm only had a nasty 300mm hacksaw in the van in a handle.
Didn’t go well started cutting the bushes back but then decided the snagging was too much and left it.
it all looks a bit shoddy now the frames I mean and the cylinder blocks. Considering starting again.
But on the other hand it’s a reflection of where I started and how life was treating me then.
I certainly don’t have the spare time to dedicate to it,
Next I filed up the boiler barrel and then trimmed out the hole in the cab sheet to fit. It wasn’t the best, I blame poor light that day in the van! I’ll sort it with some green stuff model filler, wrapping the barrel with a fag paper.
Now thoughts are turning to how to make it so the motor and gearbox can be removed.
The firebox and back plate will have to be removable. Which then means the cab rear sheet and roof need to be removable. So then I can access the screws to the motor from the gearbox.
Then the smokebox and boiler barrel need to be removable to access the motor.
Seems a fair bit! Then how to achieve that, I’m thinking screws from below that turn into soldered nuts to the cab rear sheet. Roof could stay put soldered on or have some springy brass turned down to the inside the cab sides and springing outwards enough to hold it seen that done elsewhere.
The smokebox is already screwed on from below.
Cheers for the likes and support chaps.
Ade
