Hi Mick-the-wagon ( or maybe "Maltby Mick"),
After reading your MRJ article for the third time... and looking at all of the photos on the MMP web-site which relate to the products I rather wish to ask a question or two - only 'cos the lily has been gilded so well you understand.
Post no.#32 of this thread includes an interior of one of the wagons and the view in question shows that the wagon has bottom doors. All of the RCH wagon drawings which I have seen (courtesy Tony Watts) show the door band set flush with the floor so that anyone using a shovel to remove the load would not hit the end of the shovel on the band (hence sustaining a severe jarring effect to the arm etc..) - the photo suggests that the door band is proud of the floor by the thickness of the band. For the same reason the door band fixings are recessed into the band.
After looking at the MMP photos of the etches I think that the side and end knees are of constant cross-section from top to bottom, I expect that such is a consequence of using etching for the production of the sides / washer plates / knees. The prototype knees are generally of a taper section (thinner at the top and thicker at the bottom) - if you were bothered about this aspect of the construction, and the modelling depicted here suggests that you are, then how might you introduce that taper characteristic into the models?
Running the wagons with loads all of the time is not an answer for you know that those WMR pundits will prod, poke and ask.
