Inspired by the sunshine and getting the U-Pol acid etch primer out for the tin hut, (and nearly a complete year since last touching it) I today picked up the Manning Wardle project again.
Here it is mounted in the greenhouse for spraying:
Two coats later - can you see the bent lamp iron? I wish I had
Here's my high tech support system for spraying upside down in action:
And the finished result, with which I am quite pleased. Apart from the broken off lamp iron, which will have to be re-attached with superglue. I have masked the safety valve cover and "back curve" of the firebox with copydex as I don't have any maskol, hope it works....
I am planning to spray it Vauxhall Reed Green to match the Ruston, I just hope the nozzle on that can isn't banjaxed.
