The Heybridge Railway, 1889 to 1913
RichardG
we use Ansmann extensively for our products at work.
One of the negatives of retirement is you lose all connections with current practices. Still, it sounds like I am in good company.
I would want to check, but my recollection is that NiMH chargers will detect the battery voltage and simply float continuously once they’re fully charged. They don’t shut down per se, but the current will be tiny.
I have checked the instruction book for the ACS48, from which I quote:
"The charger continues to charge the battery
pack while connected. Therefore, determine
the charging time based on the table (see
picture 2). Disconnect the battery pack
after the calculated time in order to prevent
overcharging".
This is a menace when the battery manufacturer's claimed capacity is greater than the true capacity.
I have given my battery pack a fresh dose of 116 mA for another 100 minutes, with no sign of the current falling away and no signs of overheating either. So the pack has now had 3 hr 30 min of charge.
3.5 (hours) x 116 mA = 406 mAh, which is near enough the capacity printed on the batteries and rather more than my estimates. Yet I still don't have a clue whether the pack is fully charged.
Something else I don't know is, does the charging process waste power? I mean, if a battery had a true capacity of 300 mAh, and I charged it for three hours at 100mA, would it end up fully charged? Or maybe I have to add some extra energy (extra time) to compensate for losses.
Oh, that’s not what I expected. Bit of a nuisance, but I guess you could make a timer as a charge controller. Or even a coulomb counter. Arduino?
re your question about adding extra energy. I’d say “yes” because if they get (even just a bit) hotter than ambient, then some of the charging energy has been wasted.
RichardG
From the point of view of a battery charger, the battery pack inside 'Quintus' looks like a rather large PP3 battery. I mean, seven cells, 8.4V, NiMh technology. So I am going to try the Annsmann model 'Powerline 2', which is designed to charge such PP3 batteries. Most of the spec looks sensible:
  • Intelligent charger for 1 or 2x 9V PP3 NiMH rechargeable batteries with 8.4V nominal voltage
  • Automatic charge start after rechargeable battery is inserted
  • Microcontroller-monitored charge control
  • Multiple over-charging protection through voltage monitoring (-dU) and safety timer
  • Fully-charged detection and automatic changeover to pulse maintenance charging
On the downside the charge rate is just 70 mA, so perhaps a four-hour process to recharge 'Quintus'. Better four hours and a cool loco than one hour and a big worry (Vapex) or an indefinite time and indefinite result (ACS48).
If this works, I might convert 'Lady Marion' from LiPo to NiMh. This would overcome a different worry.
RichardG
Sadly the Ansmann 'Powerline 2' seems to be completely unsuitable for charging 'Quintus'.
At power-up, the charger sends a series of test pulses to the battery pack, the pulses ranging from about 15 to 60 mA. This pulses continue in a cycle for five minutes, whereupon the charger shuts down and indicates that it considers the battery to be faulty.
There is probably a lesson to be learnt here. Most AAA battery chargers are designed, unsurprisingly, to charge AAA batteries. If you use the two-thirds AAA battery in a model you are using a non-standard battery and really, you are on your own. I've got a kitchen timer, I can use this with the Ansmann ACS48.
The Powerline 2 might still be useful - I can buy some NiMh PP3 batteries for my r/c handsets. Maybe convert 'Lady Marion' to NiMh. But I have made no progress in my quest to charge 'Quintus' accurately and automatically.
Manning, Wardle "Lady Marion" . . "Poover" battery and terminals
Boyblunder
Richard,
I have been using these "Poover" PP3 sized Li-ions with built in USB C chargers https://www.ebay.co.uk/itm/144773411390 for several things and initially found them very useful. Both have now expired after slightly less than 2 years due mainly to lack of charging in the last 6 months I think. I've no idea what the real capacity is, probably not 1200ma. Perhaps you can try one? Just need to extend the USB C socket to somewhere convenient.
Robin
RichardG
I have one of these Poover batteries inside 'Lady Marion'. The eBay listing suggests they are selling well.
It's useful to know about batteries failing, and good to see they are still for sale. I wonder what their shelf life is.
I did a bit of design planning to leave myself some access to the USB socket!
This loco also has a coaxial power connector behind the smokebox door, so I can charge a NiMh battery in situ in the loco.
The Poover battery gives me just one problem. When I refit the saddle tank, if I should momentarily touch both battery terminals (shorting them together) then the battery resets itself. I have to connect the USB charging cable for a few seconds to get it to reset itself.
Couldn't you line the relevant area inside the saddle tank with insulation tape or make up a thin plasticard cover (a bit like a miniature waiting shelter) to slip over the terminals prior to refitting the saddle tank to prevent accidental shorting?
Experiments with wheel profiles . . part 2 of 2
RichardG
When I started in 0 gauge (summer of 2021), I thought the FS wheel was really quite a crude thing; but somehow I accepted it without much thought and got on with making models. I now know, the ScaleSeven wheel will run perfectly well on 0-MF track, and a model so fitted looks a lot better. But running such a narrow wheel on a tired 0-F layout is likely to bring disappointment.
I have been looking for a middle-of-the-road wheel profile which will look better than a FS one and still run at on the 0-F tracks at NEEGOG.
The trolley runs fine on 'Heybridge Basin' but really I thought it would. I am now waiting for some cassette-deck style drive bands to let me try it over a distance at NEEGOG.
This contraption now has a drive belt. This is a square-section belt sold for cassette players and CD/DVD drives, and it is slightly sloppy. The pulleys have a vee groove with a flat base and 60-degree sides and, more by luck than judgement, they are gripping the belt beautifully. And so, the thing drives itself along. This photo also shows my experimental wheel profile.
I have rebuilt the superstructure(?) to set the C of G centrally above the pivot on the side frame, and to leave the C of G unpleasantly high. All-up weight is about 200 grams and the wheelbase is 70 mm, so much the same as a white metal wagon. Running speed is north of a scale 100 mph, so I fear I have been perceived as more hooligan than mad engineer, but the speed really only adds to the fun.
Well, I put the machine on the track at NEEGOG this morning, and it completed lap after lap without difficulty. It ran perfectly in both directions, including the curved legs of two Peco 6ft points in both leading and trailing directions. In fact, it never derailed. This was more than a mere surprise, I was amazed. I expected it to derail at a moment’s notice.
A better idea might be to reduce the flange to 0.66 mm (the scale height, adopted by the S7 standards) and keep the original tyre width of 3.4 mm. The wider tread giving the wheel as much support as possible when it runs through a 0-F crossing. This is easy to make using the S7 wheel profile tool. It also gives the opportunity to reduce the tyre diameter a little, to improve the appearance.
Arguably I am doing nothing new. The wheel standards from the Guild state that the fine scale flange can be reduced to 0.6 mm if suspension is provided. But I am staggered that this works so well on a track I have seen to derail so many models. The wheel profile seems to relying heavily on its coning too, because the flanges are so far away from the check rails.
This is the wheel profile I tested at NEEGOG today, photographed beside a ScaleSeven wheel from Peartree. The test wheel has the same shape but it is the same width as a FS wheel.
RG7 would seem to describe the standard you seek.
I don’t have a big enough ego to call this RG7, but what it is seems to fit the bill for future wagon builds on my mixed 0-F and 0-MF Heybridge Railway. It is also very easy to pull the wheels apart on their axle to create a wagon compatible with ScaleSeven, for when I have a layout run such a wagon.
The testing has all been rather satisfactory.
Wagon wheel to run on 0-F, 0-MF and (regauged) S7
RichardG
Rather encouraged by this test running I have made four “production” wheels for my next wagon build.
Minor attempt at creative photography. No problems with Slater’s choice of steel.
This time I have put a tiny chamfer on the outside of each tread, I think this makes them look better.
One thing I forgot all about at NEEGOG was choosing a B2B distance for the modified wheels. The S7 flange is thinner than the FS one, so I have settled on 29.7 mm here. The distance is set by putting a washer behind one wheel. This arrangement negotiates all of the track on Heybridge Basin.
I have chemically darkened the running surfaces, blackened the outsides of the tyres, and painted the insides. One day I will settle on a standardised finish.
So I am now set up to build a fresh wagon kit.
GER sand wagon New
RichardG
This kit is the GER Sand Wagon by Connoisseur Models. The kit comes with a 16-page instruction book filled with advice and photos of a completed kit.
The instructions mention using drawing pins to hold the model onto a block of wood. Now I have my sheet of armour plate for work with the RSU, I am sometimes using welding magnets to do the same thing.
Everything was plain sailing until I came to the solebars, which were a bit fraught. So I stopped for these next photos after the first 26 parts.
I like this photo - just about all of the excess solder is on the inside.
The first solebar overlay went on straight away and without difficulties using the RSU. Unfortunately, the anxiety of getting this on right lead me to forget to do all twelve rivet impressions on the overlay. I have undone enough brass parts to know, the half-etched locations will be clogged up with solder and I will never get the impressions in the right place. So I have accepted this and moved on. This will definitely be "my model".
The tabs on the solebars go into slots in the model, and the slots are sensibly too wide. But the tabs have to be aligned against the inner sides of the slots, which is the opposite side to where they naturally want to go. So for each side, I tacked the solebar assembly into place, adjusted these joints until the alignment was just right, and then soldered up the rest.
I am using the RSU and the microflame torch for nearly all of the assembly, and the result is needing very little clean up. Well, so far.
I have now paused to emboss every remaining rivet. There are only a few, but they are on both sides of the etch . . .
( Diversion : railbuses at the Middy and elsewhere ) New
RichardG
We went to the Middy today to see the railbus. I don't have a bucket list but I have never even been inside one of these before let alone travelled on one. And so we made the trip.
At Brockford.
At Aspall Halt.
We were both impressed by the comfortable seats and the ride! Of course it doesn't go very fast here but we had panoramic views of the countryside to enjoy.
This particular railbus is usually at the EARM at Chappel and it will be running again at the Middy next Sunday 28th June.
Simon H
At Brockford.
A pity about the wheelie bin.
At Aspall Halt.
Lovely things! I must have a ride on the one that's now on the Swindon & Cricklade Railway, which I last rode in the 1980s when it was on the K&ESR. It's been in the (mainstream) news as a lady who had ridden it to school has been able to renew her acquaintance with it recently. My little DB layout is based around the Uerdingen railbuses that were a mainstay of West German branch lines for several decades; a two-car set fits neatly in the platform. It's interesting to note how different the appearance and layout of the BR examples is, the latter sit a lot higher, presumably due to the height of our platforms.
Unfortunately I don't think I'll be able to get to the Middy any time soon...
Simon.
RichardG
This was a warm and muggy day and I was expecting the railbus to be a stuffy and uncomfortable experience, more of a pilgrimage than a gentle day out. But it was light and airy and really comfortable, even with three-quarters of the seats taken. Like many railway experiences I was born ten years too late to enjoy these. I think it is a shame they were phased out so quickly. I'm sure there were short branches like Stourbridge Town where they could have stayed on for years.
Lawrence Boul
At a glance, the front face of the tyre measures 2.2 mm wide on a S7 wheel, and 2.4 mm on a FS wheel. And this does make a difference to the appearance of the wheel.
In the debate about wheel standards there always seems to have been a focus on the flange (which impacts the track), but visually the tyre width and the visible front face are as important depending on the angle of view. I've been thinking about it of late as I need some tyres done.
The image is of a 1:64 wagon tyre facilitated by @Brian McKenzie over 20 years ago. Flanges closer to scale than commercial, but still over scale. The tread diameter is scale, the bore was dictated by available moulded centres at the time (but 3D prints here). Tyre width is 2mm which is 0.2 over for a wagon tyre. The tyre thickness should be 0.87mm deep (new) but is manufactured to 0.72mm (the front face will be less due to the tread cone, any corner chamfer etc). If the real tyre has seen wear and/or a lathe it will be less again. The rim of the centre is pragmatically chunky though. The tyre has a plain bore, so the centre lacks the benefit of the step in the prototype. Fortunately for me only one car/wagon tyre was listed at this period, so it's a one off argument, not something to be revisited often.
Old NZR wagon tyres appeared to be fine and I feel these tyres capture the effect quite well. As can be seen in the attached drawing the front face of locomotive tyres varied quite a bit. Some proprietary tyres are a bit thick, and that does impact the look of an engine, as much as tyre width or flange profile in my opinion.
RichardG
Thank you Laurence for all of this especially the drawing. The provision of a special profile 'B' for the centre axle of six-wheelers is very interesting! I wonder how much doing this would help models to stay on the track.
At the moment I am limiting my experiments to wagon wheels and this is helped by having bought some secondhand ones. Reprofiling conveniently removes rust and makes them look like new. If I can create something which looks better than a FS wheel and still runs on a tired FS track I'll be very happy. I need to be a bit cautious because 0 gauge wheels go into the model during the build. They don't readily come out unless you provide for this in the design of the W iron and axlebox, and so far I haven't tried to do this.
I am doubtful about trying an intermediate profile on a loco. There is so much investment in the build, I think the wheels are best as one standard or the other i.e. FS or S7.
Lawrence Boul
Bear in mind the NZR was a narrow gauge, originally 'colonial', railway. Tight curves and limited budget. I wouldn't draw too many conclusions on British practice from that drawing. It does show that the real thing when faced with tight curves had issues too.
In my experience you can get away with a lot when it comes to tyre profile, provided the back to back is appropriate to the check gauge. I run a bit of a bastard wheel standard that is close-ish to scale on NMRA standard track. RP25-110 and RP15-088 (US standards) wheels all perform adequately. The down side is that flangeways are excessive for all but the coarsest standard. I could tighten them up, but the back to back would probably also need to change accordingly. Finer flanges generally need suspension of some sort as well (which I have). Personally I just live with the flangeways. Doing something better, but unique, has it's downsides.
Captured wheelsets are a bit of a design flaw...
Bob Essex
At Brockford.
At Aspall Halt.
Glad you enjoyed it. I travelled on one on the Saffron Walden branch while staying with friends of the family in my early teens. The experience was marked compared to that of an ‘ordinary’ train ride of the time and has remained with me as a fond memory. In recent times I have obtained a Heljan 4mm one, (converted to P4 and with Paul Chetter sound file), and I am surprised Heljan have not produced one in 7mm. The criticism I have seen of them is to my mind unjustified. Perhaps it is judged there would not be the demand but I think any of their railbuses would be ideal for a small 7mm mini layout of the kind that are around these days.
Bob
Rob R
Back in the early eighties the KWVR used one of their W&M 'busses for a Saturday morning shoppers run down to Keighley.
No gricers, just a few locals (and the odd car load of idiots across from Cheshire), just a proper branch line doing proper branch line stuff.
The half cab allowed a fantastic view down the line, especially when you were sat next to the driver.
