I ordered a lasercut signalbox kit based on Helston to give me something to do indoors. For guttering, a length of Evergreen 080" channel was glued to the edge of a sheet of 60thou Plastikard. When dry, it was cut from the sheet 2.5mm wide as shown....
It was then glued to the signalbox wall just below the roof...
Drainpipes were bent from brass rod and attached with split pins + Loctite instant glue....
'Tother end.....
As usual, I built the roof to be removable. The steps, windows and doors will be sprayed separately for ease of painting...
The chimney breast is not fixed and will be fitted after painting. The chimney came from a scrapped signalbox....
