Hi
I have amended the thread title as here seems an appropriate place to consider the refurb of the DJH 40. I remember when the DJH 40 first came out - I thought it was fantastic and had a huge presence about it. Our paths never seemed to cross until I picked up a well-built one off Ebay; well-built but poorly running. Not a problem, as I reckoned I could deal with that.
I must confess I wasn't expecting the weight of the thing. It only had one motor, the gears were well-worn and the bogies didn't have clearance to swing under the body.My initial intention was to keep the bogie sideframes as they came and just rebuild the innards - hopefully a quick job I could get done in a week so Tim could chip it this coming weekend at the next Heyside workday. No chance.
I already had 2 of the big DJH motors in stock, and I reckoned this would be a good use for them, especially as the kit was designed around them, and I reckoned 2 of them would have the grunt to shift an 8lb lump of Pewter.
So, I removed the bogies from the body, and the inner chassis from the bogie sideframes. No problems until I had a critical look at the inner frames.
The leading unpowered axle is not in a truck. It just runs in the inverted 'U' at the front. Worse, the height is such that the leading and middle driving axles were not taking any weight. I am for the moment leaving this design as is, but have filed the top of the 'U' so that the leading axle is not taking any of the weight at all. Instead it is free to move laterally and go with the flow. Tests have shown that it should take my curves, but it's a bit early to be happy.
The middle driven axle was very slightly lower than the outer 2 driven axles, so the bearing was filed to a very slight oval so that all driven axles rested on plate glass without rock - I did actually use a chassis jig; see below.
And finally, one of the rear axle bearings, the ones directly driven from the motor, was, how shall I put it, somewhat of an agricultural fit.....
No wonder the gear mesh was all over the place.
I managed to extract the bearing using a microflame without disturbing the cast white-metal brake shoes, and replaced it. This is when I used the chassis jig so I know it is square. I tidied up all the brake shoes, sorted out the paint blemishes and resprayed...
I have ordered some more delrin cogs, and I am going to make it a proper 1 Co Co 1, with all 3 driving axles driven. It should have amazing pulling power, far more than I need, but we shall see.
