Scanlon
This week has been devoted to detailing 34010. The major construction has centred on building the lower firebox and ashpan. A lot of patience was necessary to ensure the hoppers were in "vertical alignment" to provide the pony truck with sufficient clearance to enable it to swing.
![Ashpan 2 100117.JPG Ashpan 2 100117.JPG](https://www.westernthunder.co.uk/data/attachments/62/62853-5016ca1b1bbbc1c83c67c1ec97668a59.jpg)
In this photo the pony truck had yet to be levelled out. Trials on Heyside with it in the correct orientation identified minor alterations quickly achieved by slightly reducing the overall height of the leading spring hanger bolt on the pony truck castings.
The engine body has also received attention and now the fireman's side is almost fully detailed, only smokebox sandbox and handrail to add.
![Loco 6 130117.JPG Loco 6 130117.JPG](https://www.westernthunder.co.uk/data/attachments/62/62854-1eb1d7a239361ba1b8a47287c2102681.jpg)
This photo shows the deflectors temporarily fitted to correctly locate the huge main steampipe castings in place. Progress on the driver's side has been slower but hopefully next week will see this finished and then a start will be made to install the injectors and pipework.
The tender for 73092 has also progressed and it is now well on the way to being completed.
![Tender 11 150117.JPG Tender 11 150117.JPG](https://www.westernthunder.co.uk/data/attachments/62/62855-fe3ecc1038c4f9a8d1e1412ab0897fe6.jpg)
![Tender 13 150117.JPG Tender 13 150117.JPG](https://www.westernthunder.co.uk/data/attachments/62/62856-4284447ef67581c1bb321de41c6cc626.jpg)
Rather than fit the etched lampirons cast ones from Laurie Griffin have been used. 73092 was delivered new to Shrewsbury fitted with LM style brackets, not the side on GWR variety. On transfer to the SR additional lampirons were required and two Southern castings have been used reflecting the differences is styles.
To improve the level of detail a number of castings and etches have been ordered from the Ragstone range and hopefully they can be collected at the Bristol show. This should see the tender completed.
Finally the owner of the ex Taff Vale auto coach has finished painting and lining it
![IMG_4138.JPG IMG_4138.JPG](https://www.westernthunder.co.uk/data/attachments/62/62857-98bd79b1776069ecd13df03969f3a27d.jpg)
