It has been some time since I updated readers on progress with 35022. Shortly after completing the basic running frame I started work on the slidebars and crossheads. The castings were ugly to say the least but I persevered until it became obvious they would never be remotely useable. An emergency plea for help went out to Dave Sharpe who told me he could supply a completely reworked set of castings. While waiting for them to arrive I decided to press on with building the engine body.
The smokebox was tackled first and has built up very nicely. It is bolted to the front of the framing at two points and it was a "right game" getting the internal fixing channels in the correct place within the smokebox. Thankfully there are two locating tabs to hold the smokebox in its correct fore/aft alignment. The outside steampipe covers are large whitemetal castings, the left hand one fits perfectly but the right hand one does not as this photo shows
Measurements have been taken to ensure the smokebox is central on the saddle, which is it, but this large gap will need to be attended to. This casting also needs shortening at the cab end to accommodate the cover for the inside cylinder steam pipe.
Next to be built was the cab, at first it looked daunting but following the instructions helped immensely. Earlier in this thread I said Dave Sharpe had provided up to date build instructions. Thank goodness he did because the original set had only 1½ pages and halfway through the build they petered out! The revised set has over 3½ pages! These photos show progress from frame to completion.
now with the basic "skin"
and finally
Just this part of the build has taken over 20 hours. The cab, boiler and smokebox assembly has been trial fitted one to the other and everything lines up although there is a slight gap between the cab and firebox. The revised instructions says this can occur and is to be filled.
Detailing of the running plate has started with the lubricators and the covers for the swing links of the piston valves being fitted. I had hoped to complete detailing today but find there are no oil boxes in the kit. Holes for the six that are required stand glaring at me so I'll have to find decent replacements.
A start has been made on building the complex brake gear. I am intimately aware of the complexity and devilishly difficult to fit replacement brake blocks on these locos having operated one on the main line for over 14 years. Obviously Mr. Bulleid was never invited to replace one of the leading brake blocks which ends up behind the crosshead! If he had he might have made life easier when designing the light pacifics! These photos show the leading hangers and stretchers and the linkage to the steam brake cylinders
and
This photo shows the trailing assembly which is integral with the front support for the firebox. For the moment the brake blocks have only been pinned to the hangers.
So far everything has lined up perfectly. Now to build the rest.
