Scanlon
Hi Peter,
That's the second time you have made my heart skip a beat. I was quite happy to do the work in the cab but after discussing the tank issues with my customer he has decided not to change anything. Then you raised the bunker floor issue. I quickly cut out the etch and find it is almost a 100% fit. Very slight filing around the curves which butt up against the curved walls of the water scoop areas is all that will be needed.
Seriously this is the kind of constructive observations that are oh so necessary in our hobby for all of us to get even better than we already are at what we do.
I also built a JM Fowler as my second loco for Heyside
The David Andrews kit is streets ahead of Jim's old kit but there are probably 30 years worth of kit development between the two. My loco needs a new dome and probably a new chimney and hopefully I can twist someones arm to let me have replacement castings. The loco is a lovely runner and will be on 82G at Kidderminster Carriage Works on 6th and 7th April.
Roger
Roger
