Scanlon
Pushing out the rivets on the Fowler tank was a chore but this kit runs a very close second for the darned things. There are simply hundreds to push out, many in very tight formations, to give an example on the rear of the cab the returns for the handrails have 30 rivets a piece to push out! All on a piece of etch 34mm by 6mm. You have to love them!
That said this is turning into a lovely build. Forming the various curves for the front of the running plate and under the cab was simply achieved by using the body of a marker pen to create the right radius. The curve under the cab required annealing before it could be formed easily. All the etches are very crisp and the fit is superb.
With the running plate built up a start has been made on the cab. The sides are laminated together, the outer half etch having all the rivet detail, thank goodness. The inner wall is slightly smaller than the outer etch to allow for the cab front and for the returns on the back of the cab to be soldered in flush. The fit is perfect.
A start has been made on fitting out the cab. The floor is a somewhat complicated set of etches so this will be a job for the next time. The reverser is a superb lost wax casting made up of four parts.
All that horrible solder will eventually be hidden - honest!
So the loco now looks like this. The whitemetal smokebox saddle is just put in place for the photo and the running plate is "loose" on the frames,
Regards,
Roger
Regards,
Roger
