The build of the Schools is progressing fairly well and has reached the detailing stage. In my last posting I was not looking forward to constructing the boiler and drilling handrail knob holes etc. Once again Lancastrian came to my aid with an excellent 1:1 diagram showing exact positions etc. for the David Andrews boiler. He added a caveat that the dimensions of the Northstar boiler might be slightly different and this did prove to be the case but again thanks to Ian for his help. Building the boiler proved quite straightforward although the half etched smokebox etching makes the front end of the loco slightly bulky. These two photographs show first the David Andrews smokebox
and the Northstar smokebox with the overlay.
Hopefully the addition of a boiler band will mask the "step".
Now the build has reached this stage with handrail knobs in place and detailing well under way.
Alongside the Schools I have taken on the complete rebuild of a David Andrews U class 2-6-0 which one of my clients recently acquired. I should say at the outset he acquired the "model" only after I had scrutinised numerous photos and agreed to restore it. I have to acknowledge David Andrew's help with supplying replacement parts. To say the model was lacking in quality is an understatement but I'll leave it there. This is what I started with after an early bath in cellulose thinners, you will note the frames in the background, dreadful is too good a word for them.
Only then could I really see what was right with the model, frankly very little!
The tender has been tackled first. Surprisingly it was built square but all the axleboxes had to be removed and in some cases replaced with new ones. The steps were in the wrong place, i.e. those for the front were at the back and v.v. so off they came and then repositioned
The coal space was a nightmare. I have no idea what was used for coal but it defied the bath process which usually loosens off coal along with fittings. It had to be ground out and to do this I went into the garden and my neighbours complained about the stench! This space will never be a silk purse so have agreed with the owner a full load of coal will mask the "imperfections". So now this is the restored state
Still more work to do not least those horrible lamp irons but well on the way back to "health".
Now to the engine body. Work on the tender revealed the solder used by the first builder was awful. Every last bit had to be removed before my usual solder could be reapplied. This photo shows what I was faced with after the paint was stripped and most of the original castings had fallen off.
After many hours with wire brushes, scalpels etc. this was the result
Still not a pretty sight.
The front end and bufferbeam had to be completely rebuilt and the valances properly soldered to the running plate. The latter had been spot soldered along their length and were very pliable until I got to them. The splasher tops had been soldered to the top of the splasher sides with a "nice" lip. Now they are correctly positioned but are still work in progress. The snifting valves were removed and the holes plugged and the smokebox redressed. Renovation of the cab has started but there is an issue with the handrails and beading which still has to be resolved. When received the whole cab leaned to one side. I thought it might require complete dismantling but fortunately this has been avoided by judicious use of the "gas gun". This is the stage I have now reached
There is much to do but detailing may shortly recommence.
For now the frames which as yet are untouched. I'll leave you with this photo of the valve gear as assembled by someone else!
Ouch!!!!!!
