It has been quite some time since I last posted anything about the various loco builds I’m working on. Unfortunately, a problem with my left wrist has cut down modelling by about 50% but I am getting there.
Firstly 30908 Westminster is now complete and awaiting the call to the paint shop.
Work continues on Merchant Navy 35008 and has now reached this stage.
Dave Sharp has yet again raided his spare test etches and supplied me with all the missing parts needed to hopefully complete the loco. As the fittings for bolting down the smokebox to the saddle had not been fitted by the original builder, reconstruction of the engine body had to proceed from the cab forwards. To ensure the running plate was at 90° to the cab I soldered short pieces of L shaped brass to the underside of the running plate and then the cab. Next the boiler was soldered to the cab followed by the smokebox. With the smokebox exactly where it should be the missing etches for fixing it to the saddle were put in place and bolted up. Once I was happy they were in their correct positions they were soldered in. Since then more detailing has been undertaken.
Alongside the Merchant Navy I have been building a Chowbent Fowler 2-6-2t. The etches are dated 1992 and it has a Premier set of frames, cylinders, rods and valve gear instead of nickel silver etches. More of this later.
The chosen locomotive is 40042 which had welded tank sides saving a lot of work. Initial construction was relatively straightforward as the running plate is built up on a frame somewhat similar to a Finney7 build. Unfortunately, any similarity ended there as the frame was not robust and very quickly began to sag. By good fortune the tank sides etc. were put in position before it finally collapsed.
As the bodywork progressed it became clear the two tank sides were not exactly the same length and considerable filing was required in places and gaps filled with solder. Having reached the above stage, I could proceed with building the boiler etc.. I had to be creative to space out the front and rear formers for the firebox and then used another “three hands” to enable soldering up.
There were no washout plugs in the kit but fortunately I found some in my spares box. I then tried the firebox in the frames, simple you would think but no. Although the cab front is located in slots they were not in the right place. There was a good 2mm gap at the top of the firebox while the bottom was level with the front etch. The cab front could not be moved as it would otherwise have been proud of the front of the cabside etches. Eventually the problem between the firebox and cab front was solved by slightly inclining the back of the firebox and now everything is correctly in position. The smokebox etch was difficult to fit mainly due to most of the unseen inside being of a very heavy gauge material which required a huge amount of heat before solder would take.
The outer etch was slightly too short so I had to add 0.4mm wire to fill the gap. Since then, progress has been quite rapid and most of the detailing is now in place.
Thoughts then turned to building the frames and this photo shows most of the parts.
With the frames basically bolted up they fitted exactly under the body but then came the problem of building up the cylinders etc.
Three of these parts are of 1.6mm thick material and the actual cylinder is a 9.5mm solid piece of round brass with machined ends to fit into the front and rear plates. Thankfully the cylinder has been drilled to take the piston rod and the piston valve rod, shown roughly in place, then the whole assembly is to be bolted to the main frames a la MOK. Unfortunately, none of my soldering equipment is able to get this mass of brass up to temperature for soldering. Fortunately a fellow builder has offered to build up the entire frame assembly. Phew!
