Scanlon
The Stanier 2-6-2t is now in store pending painting and final installation of the valve gear and a DCC chip, so my attention has turned to the build of the DJB Standard Class 3 2-6-2t. This is for a former work colleague and is the first tank locomotive I have built from this former kit provider. I enjoy these kits because when finished they provide an excellent representation of the prototype. That said they are not the easiest but having built two Standard 4 4-6-0's and two Standard 4 2-6-0's I believe I might have the measure of them. I'd like to build a Standard Class 5 if I were lucky enough to find a kit for sale at a reasonable price! Hint!![Roll Eyes :rolleyes: :rolleyes:](/styles/default/xenforo/smilies/rolleyes.png)
Construction of the frames has been quite straightforward with no hidden problems. My chassis jig ensured all was square before finally soldering up all the components.
![Frames 2 040215.JPG Frames 2 040215.JPG](https://www.westernthunder.co.uk/data/attachments/40/40949-38c1495583d9638a039fc940f3647896.jpg)
From previous experience I knew slidebars and crosshead would foul the side rods unless the motion brackets and cylinders were packed out from the frames. For this loco I needed to pack out each fitting by 1.2mm! To ensure the cylinders were still within the running plate I built it up and undertook some trial fitting. Fortunately the cylinder etches also require slight modification as the sides are much more vertical on these locos than on other classes, thankfully they do fit under the running plate, just.
So with the cylinder cladding fitted they look just right! I have reached this stage
![Frames 8 070215.JPG Frames 8 070215.JPG](https://www.westernthunder.co.uk/data/attachments/40/40950-8e1d89ab6c2e377c1666630a414c72c8.jpg)
I am quite surprised at the speed of this build so far but I'm sure something will trip me up.![Roll Eyes :rolleyes: :rolleyes:](/styles/default/xenforo/smilies/rolleyes.png)
![Wink ;) ;)](/styles/default/xenforo/smilies/wink.png)
