Dikitriki
I have standardised my stock on either Slater's fine scale wheel sets or AGH castings .....
Thank you for your reply Rob. I shall look forward to seeing the trackwork develop.
Hi John
What era are you modelling?
Sounds good Rob,
It will be interesting to see two versions of RB taking shape and in 7mm. There is a nice 4mm version doing the exhibitions as well.
If you do proceed start a thread we can share ideas.
I'm hoping that Laser Craft are going to do the signal box and water tower but
Rob has been taken ill at the moment.
Do you mind if I take a copy of your track plan. So. I can rework it suit my needs.
Hi Rob
I've had a play around just with a pencil
With regards to saving space I would have to replace the two double slips under the bridge with a left hand point and next to it an offset 3 way point.
I will be having the down main and empty coaching stock road in the front just so I can shunt parcel vans and may be have a DMU back and forth.
I will add a sliding traverser in from of the stores building.
If you wanted to have a play around with it on templot I would be great full. I could do a closer sketched plan to show what I mean.
I'm hoping to use hand built C&L points but may have to use a Peco double slip as I don't fancy building one of them.
All the best
Steve
Edited, I will not need the two Peco points listed on the bottom, 3 link will be pleased about that!!
Oh and a few pictures of your engines would be nice.
Very interesting times jan feb 56, when the kings where temporarily withdrawn with cracked bogies and two stanier princesses and duchesses where drafted in.Hi Compton
My era of interest is the nationalisation period between 1947 and 63 a relatively broad bandwidth. This probably has a lot to do with being a trainspotter within this period. My chosen dates are 1956-57 pre mainline diesel.
Hi Rob
A quick sketch for you, is it any good?
You can see where I've left out two double slips and changed them to a standard left hand and an off set 3 way point, this will give me a bit extra in the way of cassette storage and allow me space to add in the junction to the up Main from the parcel platform.
Many thanks
Steve
