Brian Daniels diesel workbench
I think a little bit of photoshopping is permissible here and there ;)
I didn't know the noses came completely off, that might be a handy feature as well as the bonnet doors being individual parts as well.
It's a shame they sealed in the side skirts, you could take those off on the first tooling.
Thanks Mick. Someone on the Heljan facebook site mentioned the lack of spokes on the bike, so I have just added some in Photoshop :)
Has the same individual yet pointed out the spokes should be laced around the hub? :D
This just looks convincing - especially from the 7mm photographers angle.
Brian Daniels
Got hold of a Judith Edge Yorkshire Engine Co "Janus" 7mm shunter kit earlier this week. I get the idea that this was a 4mm kit that's been made up to 7mm as to make the radiator ends it says to add a bit of wire inside the butt joint to file into a round profile, I think you will need a bit more than wire to make the large radius corners on these! It says to use Slaters MR wagon buffers but I'm struggling to see how I can use the big nut on the rear as the frames are right behind the holes on the bufferbeams. There is no mention of pick-ups so next job is to see about these. I have got a Slaters 29-1 Canon motor and gearbox for it. Instructions are a bit vague at times as it's mostly written with just a side view and plan of chassis and a couple of detail drawings but could do with a plan of the etches with the part numbers on each bit. I have made it with a fixed motored axle and rocking middle and outer axle as per kit.
