Brian Daniels
I have been building a Mercian Models PWM shunter kit recently which whilst it does indeed look like a PWM has a few shortcomings.
The first problem when making the body is the bonnet top. It's made of such a thick gauge nickle silver it could have been used as a spare for the real thing. What a job to bend it, even after annealing. Then you have to try and punch rivets out in an upturned trough. There are also no holes provided for the turned handrail knobs that go down the middle of the curve. Getting the radiator cowling to match, as near as damn it, was fun. I had to make a surround for the rad slats in the front as there is just a flush etch front provided without four holes needed for handrail knobs at the top. I made the body removable from the footplate to ease painting I hope but I think I might do this in all over yellow so being able to split it might not be an issue. Still got to work on the cab roof, not too keen on it's fit at the moment. The buffers I used are JLTRT, whilst not 100% they are self contained and do not rotate. Vac pipe is as supplied in kit but re-bent to a lower position. Couplings are from Exactoscale. With the chassis I decided to use wiper pick-ups as I thought 6 plungers on a little shunter might be too much. The sandbox casting supplied are not quite correct for these so I used some from a JLTRT 45. Again not 100% but better than the supplied ones I think. The parts supplied for the lubricator are a bit of a mystery, I just can't work out why I need a whitemetal 4mm flycrank? I am working with the bits here to hopefully make it work ok.
