Bit slow updating this workbench thread
Whilst the TC is on the back burner for a little bit whilst waiting for a few parts I thought I would have a bash at converting a new Heljan class 37 body, that came with the pink pre-production model, into an ETH one as 37425. After a rumage through the spares boxes I found I had enough bits to nearly finish it!
So what have I used:-
Pete Harvey
New etched bufferbeam, ETH bracket, Square panel under drivers window, boiler roof blanks, window frames and D above couplings.
JLTRT
ETH (from class 33), airpipes, vacuum pipe from 37, MU jumpers, buffers and headlight.
DJH
Nose side grills with an etched surround, fire pulls, headcode etches from Deltic kit and their whitemetal marker lights.
The marker lights and headlights have been drilled out to take a Miniatronics grain of rice bulbs as I do like a bulbs light to replicate a bulb. The headcode etch had to have the sides narrowed a little bit to get an even surround. Bufferbeams were cut away and plastic strip added for the beading. Boiler access steps and filler are filled as is the handrail holes in the ends. The chassis is from the 37 I converted a while back to 37250 which has a set of Pete Harvey's etched cab footsteps on already. 37425 had a set of cast bogies on it so I want to have a go at replicating these by taking the beading off the sides of some spare 37 sideframes. Unfortunatly I only have one set of snow ploughs and one spare 37 vacuum pipe at the moment, some more are on order from JLTRT so the other bufferbeam can't get any further until the postie does his bit. I have ordered some Severn Mill nameplates for it but they will be a while coming as he is moving house soon. I will be putting a Howes sound chip in this later.
