Chas Levin
Slightly slow progress on the KWStE wagons due to various factors, some railway-related some not, but I made up and fitted some safety chains at the weekend. I know these may not be quite right for c1890 but I was very taken with them in @michl080 's KWStE van photo on the previous page of this thread and there aren't that many detailing things I have information on for these wagons, so I thought I'd fit them.
The chain is pre-blackened 33 links per inch but two lots have gottne mixed together in my stock so I'm not now sure whether it came from Cambrian Models or Weinert Modellbau; the wire is 0.3mm brass, which I blackened using Birchwood Casey Brass Black and it's just the right thickness to fit through one of he chain links:
![RAI-MO KWStE wagons 20230715 (1) safety chains.jpg RAI-MO KWStE wagons 20230715 (1) safety chains.jpg](https://www.westernthunder.co.uk/data/attachments/190/190574-1eff10072033c6119717dc7dc656e155.jpg)
It's then snipped off just behind the loop - I didn't get my batch building numbers right though and only made four initially, instead of eight:
![RAI-MO KWStE wagons 20230715 (2) safety chains.jpg RAI-MO KWStE wagons 20230715 (2) safety chains.jpg](https://www.westernthunder.co.uk/data/attachments/190/190575-4cb8fa7a8a5810371ce4bf6b1f11eb30.jpg)
Then, another piece of the brass wire is popped into the other end of each pength of chain and formed into a sort of slightly elongated figure of eight, but the larger loop is snipped off early:
![RAI-MO KWStE wagons 20230715 (3) safety chains.jpg RAI-MO KWStE wagons 20230715 (3) safety chains.jpg](https://www.westernthunder.co.uk/data/attachments/190/190576-289e03f4e35c836b1d478466a119c60d.jpg)
The stright piece of wire on each chain was then popped into a hole drilled in the buffer beam, having first been dipped into a drop of thick low-odour cyano and while that went off, the remaining four were made up:
![RAI-MO KWStE wagons 20230715 (4) safety chains.jpg RAI-MO KWStE wagons 20230715 (4) safety chains.jpg](https://www.westernthunder.co.uk/data/attachments/190/190577-69e9d9b3db0ce89bd0ab0928e25a1178.jpg)
And with all eight in place, they'll just need a little touching in with some black paint where my slightly clumsy working has scraped away the black finish on the brass:
![RAI-MO KWStE wagons 20230715 (6) safety chains.jpg RAI-MO KWStE wagons 20230715 (6) safety chains.jpg](https://www.westernthunder.co.uk/data/attachments/190/190579-f8ef4ab3c881839bba3989202836df24.jpg)
