Designing For Laser Cutting
28ten
Guv'nor
In the first photo of the last set, there is an inverted 'backing panel' can this be re-fed into the machine that face down so that the inside parapet wall can be lasered on, as the other side is 'uncut' from the first pass and that way, you are almost the correct thickness for the parapet wall, just need the coping stones or brick on end coping.
Sorry if I'm teaching to suck eggs
The mdf is 2 mm thick or 3 1/2 " im guessing the parapet should be 13 1/2 " so I shall go with a 2mm, 3.2mm and 2mm sandwich which should about right
Ressaldar
I agree with the parapet thickness, therefore, you will presumably be getting x number of strips out of one sheet fot the inner face of the wall?
Should also have said brick 'on edge' - not 'on end' for the coping - it was getting late and I was still in the air with the Lancaster and enjoying the sound of four Merlins.:thumbs::thumbs::thumbs::'(
28ten
Guv'nor
Yes the visible part of the back will be laminations, and the coping will be stone, brick would be a right pain :)
28ten
Guv'nor
This should work :) I decided to engineer a slot and tab support for the insert
Inner supports
All just slot and tab no glue, making a framework
Can you see what it is yet?
Plenty of support for the liner
A quick eyeball and all the clearances are spot on first time:cool:
This is really proof of concept for an overbridge rather than part of the arches but you know how easily distracted I am.......
28ten
Guv'nor
This shows one of the problems with cutting narrow lines in thin material. If the substrate is not absolutely flat then straight lines become bananas, and it is not helped by being at the limit of line thickness in .75mm Rowmark.
They will eventually be destined for the big warehouse on Heyside
28ten
Guv'nor
Card, but not the stuff you get from Smiffs. it Pendon without the pain :))
7mm Pallet resting on big 1/32 brother. I have scuffed the ends a bit, but thats about it. Assembly time is about 1 minute to glue up, wait half an hour (or 30 seconds in my case) and remove the assembly supports with a scalpel or slitting saw and job done:)
Dikitriki
Gosh, don't those pallets show up the difference between 7mm and 1/32. I should imagine a few of those can disappear on Heyside
The Mk 2 window looks fantastic. Are they likely to be stable with changes in temperature being so thin?
28ten
Guv'nor
Another little view into my mad world......
Whilst waiting for a job to finish cutting, I started thinking of garden sheds or rather the lack of them on Heyside :)
So i fired up Autocad and in 10 minutes I had these (actually they are 1/32 as I thought bigger would be better for a first attempt)
To which I added some boards
Unfortunately I have not worked out a way of making featheredge on a laser and end on it shows the shortcomings, but if I can source some really thin ply it might be feasible
Being practical in 7mm I think a overlay lasered to represent T&G is the way to go over an mdf former
Dikitriki
I see Heyside has sucked you in. We get everyone in the end:)
Great work again. I'm full of admiration for the skills shown by you and others with the take up of 'new' technology.
Facinating stuff.
Would you be able to see the ends on the finished building? Our shed has batons on the corners so the end of the featheredge isn't visible. Could you half-etch(laser) a step in the rear of the planking so that the visible bottom edge appears thinner. The step could provide a positive location so that each plank is parallel. Does that make sense?
28ten
Guv'nor
Facinating stuff.
Good thinking, that man :thumbs: we will see later tonight :)
28ten
Guv'nor
As I said my old camera is struggling with this but here is a shot eith an attempt at faded creosote and out of interest I poked a bit of wire at it in the second left upright to see if I could do anything about nails and the answer would appear to be yes with a smaller diameter wire. I could laser the impression but i think it is just as easy and a little more random to do it by hand
Phill Dyson
mmm........so your a nail counter eh ? ;):))
I do like the shed though, very nice idea :)
Have you thought about doing a brick built station building ?
Phill :thumbs:
