I've tried the printed chucks in the lathe, and been very pleased with the result......
Giles,
I had a go myself to see what success I might get. The Cowells has a 0MT in its spindle and it's actually about half the length of a full 0MT taper. I also have a resin printer, so using a different medium.
The step chuck as drawn in Solid Edge.
It was printed on end with the stepped end uppermost and the bottom directly on the build plate. The supports were added, primarily to provide a larger foot area on the build plate in case the increased diameter of the chucking end created too much pull for the smaller diameter end on the build plate.
The printed step chuck on the lathe cross-slide with one of the wheel tyres to be used with it.
The step chuck is now in the spindle and I'm trying the dial gauge on the steel tyre to see how good it is - on this test 0.001" TIR which is way better than I expected. I thought if I got 0.002" - 0.003" TIR that would be good. Slaters commercial S scale wheels are typically to that TIR.
I furnished a 2.3mm hole in the inner end to be tapped 6BA for a drawbar - the resin doesn't lock in the taper. So that will be the next job to do but the workshop is in the middle of a major re-jigging at the moment so I'm not quite sure when I can continue with the experiment.
But thanks for the pointer to a solution to my problem.
Jim
