Rob Pulham
Modelling time at home (in Wakefield) has been a bit limited recently due to a lot going on at work which will hopefully start to ease now. What time I have had has seen further progress on the G5 to the point of needing to fit pickups and brake pull rods and here's where I have run into a few snags and would like to ask for thoughts.
Here are a few photos of where we are up to.
Now to the snags, there are holes in the frames for plunger pickups and I had planned to use some slaters ones that I have in stock but the rear ones cannot be fitted due to how the motor sits. That plan scuppered I then thought perhaps a piece of PCB across between the frames with some phosphor bronze strip running on top of the wheels which in theory might be hidden from view by the valances/sandboxes.
That idea was scuppered too as soon as I put the body on and realised that the PCB would be completely visible under the boiler - you can already see the compensation beams quite clearly which is far from ideal but that how the kit is designed and as it's supposed to be out of the box I am not about to start altering it.
Up until seeing Roger's post where he's using Gladiator pick ups, my next plan was to use the Slaters plungers on the front wheels and to short out all the wheels to the crank pins and use the coupling rods to transfer current from the rear wheels but the jury is out.
My next snag is the operating mechanism for the brakes which has kindly spun itself around almost upside down in the photos (Bah!) is quite a chunky affair and when turned the right way up and in what should be it's working position it severely restricts the swing of the bogie and I am concerned that it might not go around any sort of curve as it is.
Any ideas on how might get around either or both of these snags would be greatly appreciated because I really would like to get this finished.
