well, I have a V-twin in bits. The Guzzi was making a knocking noise, sounded little-end-ish, but wasn't.
Big end shells.
The Right hand ones (top of picture) are smooth and a little worn, more than I would have expected for a bike that is 43 years old but has only done 28k miles. There is some slight pitting on both shells at 90 degrees to the split line, so area of highest load
The left hand ones (lower and below) are obviously pitted and wrecked.
I'd be interested in opinions regarding the cause of failure.
There is not much smearing which makes me suspect that it is not a lubrication issue, or, at least not a lack-of-lubrication issue.
The pitting is crystalline in appearance, and has significantly affected the bearing clearance - it's at least 0.2 mm oversize. I detected the issue when I was taking the gudgeon pins out. I could feel the play.
Both big ends are on the same crankpin, the pin is unmarked, appears perfect, so it is likely that I am lucky that I caught it when I did - It really did not make an awful bottom-end-clunk, in fact, the noise was much more like pinking.
There is an online guide which suggests corrosion may cause this - given the bike's light usage, and it's lay-up for several years whilst we were in India, it could be condensation-corrosion. There is no white stuff in the oil, it's black/brown and oily
Other possibilities are fatigue failure due to excessive load - well, I don't thrash it, so I'm unsure about that.
Tappets on the other hand, might be a lubrication issue, though again, it is pitting, rather than any obvious wear marks; Left Exhaust, Left Inlet, Right Inlet, Right Exhaust respectively - much pitting of the inlets, the exhausts are less affected. Exhausts are likely to be hotter, and are nearer the oil pump, not that I can see that making a difference.
They are lubricated by oil from the heads coming down the pushrod tunnels and filling the buckets to the hole, and then running down the groove you can see in the Left inlet one, where I guess it drips on the cams. The con-rods have oil-squirt holes which presumably lubricate the bores, piston skirts and camshaft too. All the holes I can see are clear.
I guess now I need to decide whether to replace the shells and tappets (all ordered and on the way) or to bite the bullet, and take the engine completely to bits, which will lead to new main bearings, cam bearings, cam chain and tensioner, and anything else that looks iffy.
If I do the former, and all is well, that would be great, but there are obvious risks.
If I do the latter, there is time and money, and the liklihood of not getting it back together in time for the trip in September.
If I were convinced that it was only a condensation - corrosion - pitting issue, I might be more inclined to take the risk - thorough wash out, new oil and filter, (they were done a year ago, at which point it was just another "clattery Guzzi") and call it a done deal.
what is the opinion of the congregation?
