Hayfields 7mm 3D Printed Turnouts
martin_wynne
John,
In 7mm scale what section rail are the chairs designed to accept or is this a variable that can be changed by the user?
@Tim Humphreys ex Mudhen
Hi Tim,
pre-sets:
or custom:
index.php
The fish angle on all prototype UK REA bullhead and jointed flat-bottom track is 1:2.75 , but on most model rail sections it is steeper at around 1:1.5
It is better to set it too steep rather than too flat to ensure the key clears.
The fishing faces are dimensioned from their intersect on the rail section centre-line. The head and foot depths can then be derived if needed, but you don't need to enter them because Templot calculates them.
cheers,
Martin.
Hayfield1
John,
Thank you for the question and I see Martin has come to the rescue, I am using C&L code 125 (I have stocked up) and I see the Scale7 stores also supplies code 125
I am happy to make you a Scale7 common crossing print or a turnout print in 33mm gauge for use with code 125 rail, if you are interested PM me.
I am a Scale7 member but model to 0/0MF gauge, am planning to go to Albury next year and if wanted happy to demonstrate the system there
