Dan Randall
Heyside: 7mm L&Y, late 50s/early 60s
Thanks for that Richard and apologies for not acknowledging your reply sooner - I had forgotten I'd asked the question. :-[
Dan
Dan Randall said:Out of interest, did you have any issues with the stiles buckling during soldering?
Dikitriki said:No, I didn't. I used a hot iron and went in quickly with 145. Frankly it took so long to poke the pesky .3mm wire through the .35mm holes that the whole thing never had the chance to get too hot. The jig is clever in that it has room for expansion built into it too.
If anything I had the opposite problem in that when I cleaned up the outside of the stiles, I found that I hadn't lingered long enough on a few joins and they were dry, ie the rungs pushed in or out. It was a simple matter to swipe over the 2 or 3 with a tinned iron and that did the trick.
By the way, I chemically blackened the jig to stop any solder bleed attaching the ladder to it. That worked well too.
Dan
