Hi
The destruction of Heyside continues......
The factory on the right of the layout with the fire escape is a front facade only....
We have managed to remove the sides of the buildings without damage to leave the quoins intact. The building is being doubled in width - real mills were often almost square - and the roof will be flat. There will also be a tower to house the staircase on the back.
And from the back...
The adjacent building will also be doubled in width, but will retain the hipped roof. A word on the original construction by Trevor Smith: the windows - all of them - were cut from one piece of white plastic card, some 3' by 16''. Can you imagine that - cutting all the window panes out, all 432 of them, keeping them all aligned in the vertical and horizontal planes, maintaining thickness, and not making a single mistake. Respect
Moving along, you can see the back of the factory and houses above the station.....
We have already completed the shell of one half of the factory and cut the floors. The floors will be made into individual trays so that they can be removed from the building to be worked on - detailed interiors and lighting etc.
And from the other side, you can see the huge improvement (I think) in deepening the building and providing a proper hipped roof.
Only one way to go from here
