Dikitriki
Richard - I take it these are the high output, non-dimmable type strips?
I would appreciate your opinion as to the desirability (if any) of dimmable LED lighting given your experience to date?
Do you consider that regulating the level of lighting by reducing or increasing the spacing of lighting bars would give adequate variability?
Given my cramped room height and width I'm tempted to install layout lighting bars on a flexible mounting system (tracking) to give background lighting too instead of separate flourescents / other.
Tony (poised ready to order a load of LED lighting).
Hello Tony,
You are correct, the LEDs are high output, non-dimmable.
Doesn't whether they are dimmable or not depend on what you want? A Dave Rowe 'Catalunya' type layout that goes from day to night and back, maybe, but for my purpose, I needed good light to see the layout. So I did not consider dimmable, and the ones I had are not too bright to worry about it. In fact, I do not think they would be sufficient on their own to light the layout. The room it lives in has fluorescents on the wall and spots on the ceiling.
I do think the spacing of the bars would regulate the light, but I was after an even light, and didn't want any gloomy spots (despite the setting!). I don't think it would be easy because there is a reasonable spread of light from any bar (130 degrees if memory serves). You would again have to work out your needs and experiment accordingly.
I would also add that the 4 bars we have in operation were only commisioned a week ago, so it is too early really to have much experience.
