Finishing the Modelu lamps
Ian_C
Scale7JB, thanks for confirming rear lamp. Looking at colour photos again I see the lamp on the tender looks just the same as the lamp on the front when not lit. Here's how they turned out...
- Humbrol matt brown enamel, AK Worn effects fluid and Vallejo Model Air acrylic used for the painting.
- Small hole drilled in the base to mount them on cocktail sticks. Clean with a wipe of IPA and base coat of Humbrol enamel. Dry overnight.
- Couple of coats of Worn Effects. Dried over the stove for 15 mins or so, then 3 thin coats of white acrylic. The area behind the lenses is painted black. Over the stove to dry.
- One cup of tea later...moisten the white paint with water and scratch a little off where the lamps have been worn or bashed.
- Glue the clear lenses in with ZAP Canopy Glue. Lamp oil and grubbiness from a little black and brown panel line wash.
- Class G, light engine with up to 2 vans. Looks the part.
